Documentation for Users
1.3.1
Perception Toolbox for Virtual Reality (PTVR) Manual
"Ideally, your ultimate methodological goal is to place a subject's eye at the origin of a perimetric system." Psychophysical Mantra.
Figure 1:. A frog's eye is placed at the origin of a perimetric system. (image of the frog from Charles J. Sharp, CC BY-SA 4.0, via Wikimedia Commons).
The standard practice in Vision Science is to specify the positions of visual objects by using a perimetric coordinate systems whose ORIGIN is chosen as the VIEWPOINT for the user. We already saw how this is achieved in the real world with most ophthalmological devices in this Vision Science Section.
Thus, in the real world, the experimenter needs to make sure that the subject's eye is exactly at the Origin's position, or very close to it so that visual angles can be validly approximated (see section on approximation of Visual Angles).
The points above lead us to the following key question :
How does Virtual Reality allow us to achieve valid visual angle approximations ? [QUESTION 1]
To answer this question, we consider two issues for clarity of presentation (although they are cleary interdependent) : A/ stabilizing the head and b/ stabilizing the eyes.
To make this question very explicit, it is worth emphasizing that the present section deals only with experimental situations where the VIEWPOINT is static in the virtual world.
Consequently, as the subject's head (and thus headset) is allowed to move freely in VR, the challenge for the experimenter is to maintain the headset as close as possible to the viewpoint (Figure 2). Otherwise, the validity of the visual angles validity decreases.
Figure 2: Schematic animation showing the headset translating in the vicinity of the viewpoint.
The experimental PTVR solutions that aim at responding to Question 1 are presented below. Note that it is recommended to use them in synergy if possible:
The most obvious solution is to use a chinrest as in usal experimental setups in Vision Research laboratories. Of course, this solution removes a lot of the huge possibilities of Virtual Reality. However, the advantages of using VR over standard experimental setups remain large and many VR papers report using a chinrest in their experiments.
&emsp e.g. Denkinger, S., Antoniou, M.-P., Tarello, D., Levi, D. M., Backus, B. T., Bavelier, D., & Chopin, A. (2023). The eRDS v6 Stereotest and the Vivid Vision Stereo Test: Two New Tests of Stereoscopic Vision. Translational Vision Science & Technology, 12(3), 1. https://doi.org/10.1167/tvst.12.3.1
The advantage of using a seated subject is that it allows a reasonable control of the body's position (up to the neck) so that only small head movements are possible. This situation is actually quite close to the situation with a chinrest as the latter is far from always producing a perfect immobilization of the head.
The main steps are the following:
Figure 3: An older professor would like to create a viewpoint at the approximate location where the subject's head position will be during the experiment. (Image of the Professor from Videoplasty.com, CC BY-SA 4.0, via Wikimedia Commons) | Figure 4: The professor first shifts the global origin to the desired viewpoint (Coordinate Transformation). The new origin is thus now at a height of 1.2 meters above the global origin in figure 3. | Figure 5: The professor then creates a point M (x=0, y=0, z=1.2) whose coordinates are now specified with respect to the viewpoint. |
In preparation
In preparation
In preparation
in ... \PTVR_Researchers\Python_Scripts\Demos\Rotations\
Python file | Description |
rectangles_looking_at_current_CS_origin.py | Try and move your head to be exactly at the origin of the current Coordinate System where all rectangles will be all looking at you !
